Constant paper jams
  • Reeves
    • Apr 2012
    • 294
    [Jamming] Constant paper jams
    Hi I have a Xerox WC 7535 its having constant paper jams both A4 or A4R plan or gross paper its jamming after the fuser unit just when it reaches the exit rollers have changed reg sensor fuser exit sensor but still having paper jams at the same area and the error is 377-201 I even changed the all fuser unit still its jamming what could be the problem
  • shinchan
    • May 2011
    • 195
    Re: Constant paper jams
    try replacing the registration clutch.
    usually the registration clutch is dirty from rust dust.
    Do not spray / clean registration clutch using WD-40 / oil based cleaner.
