Versant 80 ross ribbon cables
  • big mike
    • Sep 2012
    • 155
    How do you release the ribbon cables? It looks heavy duty. Older printers had the flap that folds up/down to keep pressure on it. Does this pull out to release the tension?
    Also, I noticed the laser windows are dirty on the inside and are glued/taped in place. Any advise will help. Thanks!
  • big mike
    • Sep 2012
    • 155
    I figured it out. It folds flat to remove the ribbon cable.
