Xerox 252 has a fat magenta line
  • howsimple
    • Jul 2015
    • 11
    Hi, When I print, I get a fat 1" line along the whole print. Please see picture. Happens to all the prints at the same location. Can anyone help. Thank you!9-24-2021 3-54-02 PM.jpg
  • jhalfhide
    • Apr 2015
    • 451
    Re: Xerox 252 has a fat magenta line
    ROS clean, do all colours.
    Sent from my LYA-L09 using Tapatalk
    • WIWA
      • Mar 2009
      • 97
      well it looks like Ros lens exposed to toner /check machine filter/clean Ros window if still go down to developer housing for contamination easy to check just take out cover and check developer at the mag roll for a even toner/developer brush.
      Hope this help,
      Wiwa72 Gonzos build v.1.0
        • 22973
        This looks like the ABSENCE of YELLOW, to me.
        Remember, this is CMYK: subtractive color, not RGB: additive color. =^..^=
        • Caffeine
          • 389
          Agree, the problem color here is clearly yellow, not magenta. Magenta is there, so it is working fine. And the width of the band makes my first guess contamination on or in the ROS window for yellow. (Which is very common, PARTICULARLY on yellow.)
          If the toner dust is on the outside of the yellow ROS window, you can clean it with some gymnastics and a swab. If the dust has gotten sucked inside the ROS unit and is on the inside, on one of the mirrors or lenses, you have to completely remove it and open it up and clean everything extremely carefully. (Much bigger hassle.)
          • Tecnico_Xerox
            • Jan 2019
            • 54
            dirt on ros window yellow
