Xerox j75
  • Hassann
    • Jul 2023
    • 82
    Xerox j75
    Hello
    xerox color j75 error code 117-325
    Any advice
  • adriansto
    • 2387
    Originally posted by Hassann
    Hello
    Any advice
    117-325 = Contract Manager RTC Hardware Fail = problem on ESS NVM pwb. Check battery voltage , reseat pwb or change the pwb.
    • Hassann
      • Jul 2023
      • 82
      Battery it's ok , how to reset pwb ?
      i did nvm initialization but not helping me
      • Hassann
        • Jul 2023
        • 82
        By the way the date is wrong it's 3/1/2050
        • adriansto
          • 2387
          Not reset but reseat mean disconnect and reconnect the electrical connector. You can try to remove battery then resold it again but I think you need to replace the pwb.
          • xcopytech
            • Aug 2006
            • 1794
            Replace ess nvm pwb.
            Battery was removed from ess nvm pwb so now you have 117-325 and wrong date.
            • Hassann
              • Jul 2023
              • 82
              Is there any thing i can try before replace ess nvm Because it's not easy to find it in my place
              • Milo Wilson
                • 502
                Can't seem to find a 117-325 listing for J75.
                • xcopytech
                  • Aug 2006
                  • 1794
                  If you removed battery from ess nvm pwb, then only solution is to replace ess nvm pwb, same ess nvm pwb is also for c550/560/570 and for d95/110/125/136
