Xerox Altalink C8170
  • hrtl
    Inkyfingers
    • May 2015
    • 27
    I'm running a Xerox Altalink C8170 with Fiery RIP, the machine is essentially new (13,993 impressions) and it has started to throw the following error:
    "There is a problem with the Xerographic system"
    Error code (shown in web interface)
    03-561-00 – which really only says to reboot the machine, which I have done numerous times at this point.
    Error codes (shown on device screen)
    393.324.00
    343.348.01
    343.348.00
    I have turned off the machine, waited, etc. etc. to no avail. I also cleared the non-volatile memory via admin login and did a software reset.
    I think the fuser unit might be shot?
    I'd appreciate any help with this & thank you in advance!
  • xcopytech
    • Aug 2006
    • 1794
    You have problem with YMC developer drive.
    • hrtl
      Inkyfingers
      • May 2015
      • 27
      thank you & yes... the service menu showed a YMC Dev motor fail 343-348-01. I pulled the drums and put it all back in place. BINGO! back in business.
