Xerox C560 paper edge issue
+ More Options
Posts
  • stanekl
    • Feb 2025
    • 2
    Hello,
    I am encountering a problem with my Xerox C560. When I am printing from tray 5 on SRA3 250+gsm (almost all the time) every print starts differently from the paper edge. I was doing test on 10 prints and the print starting point differs +-3mm so it is almost impossible to get the right alignment for trimming and also for manual double side printing on 250+gsm media.
    Is there any paper edge sensor I should clean or is there a way to correct this issue?
    Thank you for your suggestions and any help,
    Lukas
  • xcopytech
    • Aug 2006
    • 1794
    Adjust registration NVM
    • stanekl
      • Feb 2025
      • 2
      Thank you for your suggestion. Will that affect that every print would be on the same spot from the paper edge in printing direction?
      Could you also provide a how-to?
      Thank you for your help
      • Marcino84
        • Feb 2025
        • 4
        I think that you want expecting too much from this machine.
        ​​​​​CED paper tells you that machine have tolerance for image registration. See attachment
        You can do some corrections on X and Y etc but it's not prefect and will be swimming.
        From control panel admin login tools maintenance paper settings (you must find).. first you must add new custom special paper next you can change position correction in it's profile.
        • Detonation
          • Feb 2010
          • 410
          Check if the grey paper guides on tray 5 are not too easy to move.
