Versant 80 error 078-215
  • bmt_hr
    • Mar 2011
    • 128
    [Error Code] Versant 80 error 078-215
    Hi, machine give me a error 078-215 and jam papire in fuser. But when I print from internal trays print OK. Error is only when I print from tray 5, 6 or 7.
    Thx
  • xcopytech
    • Aug 2006
    • 1790
    Multifeed check sesnor
    You can disable multifeed sensor in custom paper stock
    • bmt_hr
      • Mar 2011
      • 128
      I deleted all the user created papers where is this option. The error persists. Do you know what sensor it is?
      • xcopytech
        • Aug 2006
        • 1790
        Multifeed sensor is in OHCF.
        Create customer paper and disable multifeed checking in paper settings
        • bmt_hr
          • Mar 2011
          • 128
          I took the tray from the Xerox 2100 and put it on the Versant 80 and it works perfectly. I put this faulty tray back on the 2100 because every paper needs to be created there for printing. I hope it works
          • xcopytech
            • Aug 2006
            • 1790
            You can disable multifeed sensor in diagnostic mode, dc131 nvm read write
            • bmt_hr
              • Mar 2011
              • 128
              OK, I will try that on Xerox 2100. Thx for answer.
              br
