xerox 7545 ibt and toner problem !!!
  • Shahn
    • Aug 2017
    • 30
    xerox 7545 what all should be cleaned or replaced ?
    i know that compatable toner was used and ibt belt has marks.
    ibt units roller that touches ibt cleaning blade also a little bit damaged.
    please throw your knowledge on this
    WhatsApp Image 2021-12-06 at 6.07.04 PM.jpgWhatsApp Image 2021-12-06 at 6.07.04 PM (1).jpg00000001 (1).jpg
  • GIUBOSS
    • 1435
    Re: xerox 7545 ibt and toner problem !!!
    [ATTACH=CONFIG]51000[/ATTACH][ATTACH=CONFIG]51001[/ATTACH][ATTACH=CONFIG]51002[/ATTACH]
    you answered yourself, use OEM toner, check which drum unit leaves marks, if the itb unit is damaged or at the end of its life replace it, do you have PM parts counters?
    • Tecnico_Xerox
      • Jan 2019
      • 54
      Hello,
      What I see is that the areas with high densities are not melting correctly into the paper and are dirtying the fuser.
      First it cleans the fuser of the toner residues and then performs a Max-Setup to lower the color saturation that the printer has, this is very common when alternative toner is loaded in Xerox equipment.
      Luck
      • shinchan
        • May 2011
        • 195
        or you can try change the paper type to heavyweight.
        see whether the problem dissappear
