Xerox C9065 and 12-299 code , not listed in edoc for that device
  • copytechman
    • Nov 2008
    • 939
    I know its finisher problem and its a pr finisher, but that code isnt listed in the pr finisher status raps. Does anyone have any insight on what exactly this code relates to?
    Regards.
    A.
  • adriansto
    • 2387
    Re: Xerox C9065 and 12-299 code , not listed in edoc for that device
    Regards.
    A.
    Check Business Ready Finisher edoc.
    • copytechman
      • Nov 2008
      • 939
      Found it thanks! Turns out I was given the incorrect info regarding which finisher was on the device. Appreciate the help thank you!
      A.
      • Dech
        • Aug 2014
        • 48
        Regards.
        A.
        012-299 Compile No Paper Sensor ON Fail [IMG]file:///C:/Edoc/common_e2/images/full_a.gif[/IMG]
        Bsd-on:CH16.60
        [IMG]file:///C:/Edoc/common_e2/images/description.jpg[/IMG] The Compile Tray No Paper Sensor is not turned ON within the predetermined time.
        Cause/Solution
        Check the following:
        • Improper installation or malfunction of the Compile Tray No Paper Sensor (DC330[012-151])(PL 26.81)
        • Malfunction of the Exit Motor (DC330[012-004] through DC330[012-009])(PL 26.69)
        • Malfunction of the Eject Clamp Motor (DC330[012-088] or DC330[012-089])(PL 26.68)
        • Malfunction of the Sub Paddle Solenoid (DC330[012-080] through DC330[012-082])(PL 26.73)
        • Slack on the belt
        • Detached belt
        If no problem is found by the check, replace the Finisher Main PWB. (PL 26.65)
