Xerox 700 093-315
  • MrBafner
    • Apr 2011
    • 61
    Xerox 700 093-315
    I managed to fix the scratch issue on the image .. it was a bit of toner on the black shelf / panel under the black / cyan drums/developer unit.
    However now, I am getting 093-315 .. I have replaced the toner dispenser motor, it has a new developer unit and the shoot is filling up after I changed the toner dispenser motor.
    I am entering 093-006 to test the dispenser motor and it keeps saying it is the wrong component number.
    Can someone please tell me the correct component number for the Xerox 700 magenta toner dispenser motor?
    Much appreciated and thank you
  • irdicheku
    • Aug 2019
    • 17
    Re: Xerox 700 093-315
    try 093-007
    • InterfaceP
      • Jun 2013
      • 488
      If the toner chute's filling up then its not the dispense motor. Check the developer drive for functionality
      • xcopytech
        • Aug 2006
        • 1794
        Did you reset proper NVM for error
        • SeniorTch
          • Jun 2017
          • 117
          to solve 93-315,
          check developer unit gears, empty magenta dispenser, restore nvm 762-313 to 0
