Fuser system error with error code 310-372
+ More Options
Posts
  • Reeves
    • Apr 2012
    • 294
    [Error Code] Fuser system error with error code 310-372
    Hi I have a xerox Altalink C8055 displaying error code 310-372 have changed the fuser motor and new fuser unit still am getting the same error code I checked for gears and sensors around fuser and fuser drive they are all okey what could be the problem
  • Detonation
    • Feb 2010
    • 403
    Don't have the EDOC on hand, but I think it's a overheat error. There might be a NVM te reset?
    • xcopytech
      • Aug 2006
      • 1792
      744-001 to 0
      • Reeves
        • Apr 2012
        • 294
        Originally posted by xcopytech
        744-001 to 0
        I did reset 744-001 to 0 it worked then again the error code came back
        • xcopytech
          • Aug 2006
          • 1792
          310-372 is not related to fuser motor. If you tried new fuser then next step is MDM pwb
          • shinchan
            • May 2011
            • 194
            any sound of fuser turning when you turn on the machine? if no sound, straight to error. it could be the ih driver.
            • Reeves
              • Apr 2012
              • 294
              No sound no warming up fuser is not heating up
              • shinchan
                • May 2011
                • 194
                yup that's happened with me too once...
                error showing 010-375 /310-375 immediately after I turned it on
                replace fuser, still getting same error. The weird thing is if I turn on the machine with the cover on, the error code change to 010-376/310-376 ๐Ÿ˜‚
                I tested the old fuser to other working machine, and it works great...
                I ended up replacing IH driver, on that machine.
                manual book
                1. replace fuser
                2. if not working then replace to MDM PWB
                someone with experience told me, do not go straight replacing to MDM PWB
                if the error code is 010-37x / 310-37x, it could be the IH driver
                if the error code is 010-38x / 310-38x, it could be the fuser motor
