Versalink / Altalink delete a job stuck on error/jam
  • szanka
    • Dec 2011
    • 29
    We got some tender to cover, one of the point is:
    The system must delete non-printed work, interrupted work, etc. after a set time, after a failed attempt to print on the device (e.g. due to lack of paper or consumables). After removing a device fault, e.g. a paper jam or lack of consumables, the device must not resume/continue printing but remove the job from the queue so that other users can use the device after the fault is removed."
    I remember that workcentre machines had this feature, but I cannot find this on versalink and altalink.
    Is there a way to delete job on conditions stated above?
    The option to delete held jobs after set period of time does not work in this case.
