Print Image distored, Xerox DC700i
  • PaulNeB
    Operator
    • Dec 2023
    • 11
    Hello,
    What could be the cause of this?
    Xerox DC700i Print image at SRA3 format in the pressure direction on the
    left 3-4 mm longer than right. All colors suitable.
    Exchange the IBT-Belt the right thing, Laser, Sensor?
  • adriansto
    • 2387
    Sorry but what is the pressure direction? Can you post image of the print?
    • PaulNeB
      Operator
      • Dec 2023
      • 11
      Image not possible at the moment.
      Paper 13" x 19"
      A frame 450 x 300 mm
      One frame side 450 mm, other side 454 mm.
      • adriansto
        • 2387
        Usually the backup roll ( inside the IBT asssy ) is worn out and there is different pressure between inboard and outboard sides of paper.
        After replacement must be run trapezoidal adjustment.
