Xerox 5855 2 sidded copy problem
  • efe311
    • Oct 2008
    • 114
    Xerox wc 5855
    Did't copy 2 sidded copy only from ADF
    Copy 2 side from flatbed but did't copy from ADF
    Sent from my SM-N950F using Tapatalk
  • GIUBOSS
    • 1436
    Re: Xerox 5855 2 sidded copy problem
    You mean he takes the paper and copies only one side? Does not take the sheet, does not see the sheet in the ADF ... ?? Have you checked / cleaned all sensors?
    • efe311
      • Oct 2008
      • 114
      1side copy is ok
      2side copy not work
      From the ADF
      • xcopytech
        • Aug 2006
        • 1794
        WC5855 have SPDH. It scan original in one pass.
        Check, clean or replace side 2 scanner assembly PN 041K06850.
