D125 runs dark
  • big mike
    • Sep 2012
    • 152
    D125 runs dark
    I was surprised how quickly the exhaust filter gets dirty. It has a total of 889k on it. The target density 752-006 = 339. I believe the default is 413. The solids are a little too dense in my opinion. Can you set these to run lighter, change the target value? Otherwise, these are great b/w machines.
  • big mike
    • Sep 2012
    • 152
    On my D95, I set up 'baseline adjustments' and it seemed to work so far. I set 752-006 to 500. It is 413 on the factory nvm sheet. It detoned, runs clean and still at 500.
    I checked the D125 factory nvm for 752-006 and it is 339, which makes it run darker. Has anyone run into this problem?
