Hi
I am looking for an advice regarding error code 305-132. Machine jam at the same point (please see photo) all the time so scan copy from adf is not possible. Replacing whole adf solve the problem so I sm sure the problem is only at adf itself.
Inverter sensor is working but obviously is not activated because paper does not reach it. Turning manually green jam gear it move paper like it should so there seems to be nothing what could block the paper path.
Has anyone experienced this issue or can advice what should I check? I suspected rollers where the paper stop but after cleaning still the same jam.
Doc1.pdf
Doc1.pdf
