Xerox wc 7855 makes dirty copies
  • Sema
    • Apr 2016
    • 36
    Hello colleges
    I have a machine xerox wc 7855 makes copies with dirty dots at the edges especially when using long edge feed and sometimes the dots reach the center of the copy.
    The dots may be of any of the four colors cyan, black,yellow or magenta and it comes worse when you interchange the drum cartridges.
    I replace drum cylinders(OPC), I serviced the belt assembly, and the entire machine but no change.
    Attached a copy indicating the fault.COPY.pdf
    I need some help
  • Jettdog
    • May 2021
    • 48
    Re: Xerox wc 7855 makes dirty copies
    Originally posted by Sema
    Hello colleges
    Attached a copy indicating the fault.[ATTACH]52447[/ATTACH]
    I need some help
    Whats the belt cleaner or waste toner box look like? Belt cleaner may be full
    • copier tech
      • 8164
      Hello colleges
      I need some help
      Are you using genuine Xerox toner ?
      • shinchan
        • May 2011
        • 197
        My guess
        you need to replace cyan drum. there are cyan dots
        you may need to replace black drum.
