Xerox 7120 activation code
  • martel420
    • Mar 2022
    • 4
    Hello,
    I bought few year ago a xerox 7120 for personal use (& family), the supply plan expired and i'm not able to print anymore, is there any way to turn off the supply plan and get a activation code for the non sold plan?
    Thanks,
    SN: 3326239002
  • koombaya
    • Jun 2022
    • 8
    Re: Xerox 7120 activation code
    Hello, did you solve your problem ?
    • martel420
      • Mar 2022
      • 4
      Not yet ..
      I need the activation code to use it without contract
      • GIUBOSS
        • 1436
        Try replacing the toner and let me know
        • Murv
          Sr. Escalations Analyst
          • Mar 2021
          • 182
          As a rule, putting a sold toners in a machine converts the plan from metered to sold and you're golden.
          • martel420
            • Mar 2022
            • 4
            Do i need to replace all colors (black / cyan / pink / yellow) in order to make it work, or just one? Will the previous toner i have still work?
            How do i know the toner i will buy will be metered or sold ?
            • Jack79
              • Jul 2014
              • 312
              I am not sure if inserting sold toners will change it but worth to try. For 722x series once machine ask for pin you will not be able use sold toners but maybe for 7120 it will work.
              You can recognise sold cartridges from parts number. These finish with numbers 57 black 58 59 60 cyan
              • martel420
                • Mar 2022
                • 4
                I made it work again by going into tech mod and reseting the machine, now the toner are detected and i can print back again (with the same toner as before)
                Thanks everyone!
                • Abdo98
                  • Jun 2019
                  • 61
                  Hello,
                  Thanks,
                  SN: 3326239002
                  30493154
