WorkCentre 6515DN - repeated vertical lines
+ More Options
Posts
  • karina
    • Oct 2016
    • 11
    Hi,we've encountering a very strange problem with a brand new Xerox 6515.Every print of the machine comes out with repeated vertical lines on one side of the page. 6515.jpgSo far these parts were changed: drums, transfer belt, toner cartridges. No way to make those lines go away.We cannot figure out what part is causing this issue. Does someone have any idea about what could be the reason and how to solve this?Thank you
  • Jettdog
    • May 2021
    • 48
    Re: WorkCentre 6515DN - repeated vertical lines
    Does it do it in all colors?
    • karina
      • Oct 2016
      • 11
      Black only
      • Jettdog
        • May 2021
        • 48
        If you've already replaced the belt and imaging unit, it could be anything. Bad laser, bad high voltage, something in the black development drive. Since it's brand new, I'd call Xerox and have them handle it.
        • karina
          • Oct 2016
          • 11
          Hi,
          eventually we called Xerox and they decided to replace the machine.
          Thank you anyway
          Kari
