Xerox Altalink C8045 only b/w output
  • big mike
    • Sep 2012
    • 152
    This copier was only used for b/w output. Is there a centreware setting to convert i to b/w? I scrolled through and don't find it. It's not in tools or diagnostics. A tech swore it is in the c/ware software. Any reply is appreciated.
  • shinchan
    • May 2011
    • 195
    Re: Xerox Altalink C8045 only b/w output
    In older version / workcentre / docucentre
    you have to turn on accounting / auditron.
    after turning it on, you create a user name, no password is okay.
    in that user name, you choose option copy and print service to black and white only
    OR
    turn on authentication.
    then in access control>feature access> color copying locked
    • big mike
      • Sep 2012
      • 152
      Thank you. I will try it!
      • jascan
        • Apr 2022
        • 1
        hi everyone out there any ideal for altalink c8000 series which version of firmware is good for color print and copy thanks..
