Xerox VersaLink C7020DN - white screen
  • Kenny
    • Jun 2009
    • 536
    Hi guys,
    we have a
  • Kenny
    • Jun 2009
    • 536
    Re: Xerox VersaLink C7020DN - white screen
    Would this need a new SD CARD?
    • Gaffers01
      • May 2011
      • 335
      Not sure exactly what you have done to reslove but there is a bulitin for a White screen Issue.
      Problem:
      White screen and printer boot normally
      Cause:
      Faulty ESS PWB (version C0)
      Solution:
      Change ESS PWB
      • shinchan
        • May 2011
        • 197
        Originally posted by Kenny
        Hi guys,
        we have a
        try reseating the UI cable.
        • Kenny
          • Jun 2009
          • 536
          Hi guys,
          we are going to be ordering the board,
          can you confirm the part no:
          960K89393 PWB DOES IT NEED TAG001?
          • Kenny
            • Jun 2009
            • 536
            Can anyone confirm?
            • Alexandr
              • Mar 2022
              • 12
              Hi guys,
              we have a Xerox VersaLink C7020DN that has a constant white screen, I have reseated the SD card and powered the machine off/on but still persists,
              Not limited knowledge on Xerox’s so any help would be appreciated!
              Remove the cover on the ESS PWB board. There are 8 LED indicators. Can you make a screen? I will tell you what the problem is. I'll give you the part number too.
              • Kenny
                • Jun 2009
                • 536
                Problem:
                Cause:
                Solution:
                Change ESS PWB
                Hello,
                do you know if it needs TAG001???
                • Alexandr
                  • Mar 2022
                  • 12
                  Hello,
                  Use information provided below to install appropriate ESS PWB and associated firmware version.
                  Spares
                  For spares replacement in the field:
                  • An ESS PWB with the current (B0) controller chip should be replaced with another ESS PWB with the current (B0) controller chip.
                  • An ESS PWB with the new (C0) controller chip should be replaced with another ESS PWB with the new (C0) controller chip
                  Device SW Level
                  ESS PWB XX.0X.XX XX.2X.XX
                  B0 Yes Yes
                  C0 NO Yes
                  CAUTION:(C0) ESS PWB must have a software level of XX.2X.XX or higher to function.
                  Devices manufactured with the current (B0) ESS PWB can be identified by the following:
                  • Tag #1 (Tag #2 in the case of B400/405 only) is NOT marked off on the tag
                  Devices manufactured with the new (C0) ESS PWB can be identified by the following:
                  • Tag #1 is marked off on the tag matrix of all devices, except for B400/405. These devices (B400/405) will be identified by Tag
                  Figure 1
                  [IMG]pws://bceextract/Xerox/BUS/CONTENT/Bulletin-VersaLink_B7035f/X205138911237020433131993787230719556.dat/ii_T8859-02att1.JPG[/IMG]
                  B0 / C0 ESS PWB Spare Part Numbers:
                  Spares
                  • The current SD card should ONLY be installed on a (B0) ESS PWB (w/o Tag 1).
                  • The new SD card should ONLY be installed on a (C0) ESS PWB (w/ Tag 1).
                  For the SD card replacement process, please follow the instructions in the service manual.
                  Service manuals for all affected products will be updated with the new part numbers along with the appropriate Tag references.
                  • Kenny
                    • Jun 2009
                    • 536
                    Problem:
                    Cause:
                    Solution:
                    Change ESS PWB
                    do I need to use the SD card that is currently on the machine and put it on the new board or not?
                    • Kenny
                      • Jun 2009
                      • 536
                      • xcopytech
                        • Aug 2006
                        • 1794
                        Go to dc132 in diagnostic mode
                        • Kenny
                          • Jun 2009
                          • 536
                          i have tried to adjust the serial numbers but it says the serial is wrong,
                          can anyone provide the full instructions on replacing the ESS-PWB, tried to update firmware but when i went into the special boot mode it didnt give me a firmware update option,
                          the machine serial number (IOT) and product number (IOT) is different to SY1 +SY2
                          the billing data is all the same and SY1 +SY2 for serial number and product number are the same
                          • xcopytech
                            • Aug 2006
                            • 1794
                            Have you transfer seeprom from old ess pwb to new
                            • Kenny
                              • Jun 2009
                              • 536
                              i did try that but the screen turned black and came up with a 117-(cant remember the last 3 digits) error in red writing
