Xerox C60 print strip
  • Apach
    • 157
    Hello,
    On picture you can see strip in lighter color. I try to change: cyan color drum and cyan developer asm with new one because on test print page only cyan show this stripe, but still the same problem. Color meters is cca 60k copies. All toner is genuine. Do you have idea what is wrong? Thanks
    There is no stupid question, just stupid answer
  • xcopytech
    • Aug 2006
    • 1792
    Re: Xerox C60 print strip
    Clean ROS
    • Jack79
      • Jul 2014
      • 312
      From your photos I cannot say that problem is definitely
      with cyan. It can be any other colour. Print cmyk samples to see if the problem affect only one colour.
      • Murv
        Sr. Escalations Analyst
        • Mar 2021
        • 182
        +1 on cleaning the ROS
        Here's a vid for a Docucolor ROS cleaning procedure, but it will apply to the C60 and Primelinks, as well as others using the same/similar IOT.
        • Apach
          • 157
          Exactly ROS problem. I forgot to clean it. I was on vacation so I didn't get to thank you earlier. Tnx again.
          • JR2ALTA
            • Feb 2010
            • 2030
            Click "thanks" and/or "Like" for his help.
            • jhalfhide
              • Apr 2015
              • 451
              Annoys me no end that these models have no cleaning wand.
              Sent from my LYA-L09 using Tapatalk
