C75 error code 042 325
  • positiveg
    • Jun 2018
    • 299
    Our printer has been down for a year then we got it back up and have now been getting the Error 042-325
    Tech not sure I've seen the yellow drum
    but we've replaced that drum several times and still getting the same error
    would it be the main motor drive
    oh and another thing the tech found that the motor for the waste toner was jammed, possibly because of the non use of the machine?
    Sent from my SM-G780G using Tapatalk
  • Jimdale
    • Apr 2022
    • 4
    Re: C75 error code 042 325
    A bad belt edge sensor will cause that problem. I had a 250 that had that fault intermittently being caused by a bad bypass tray motor.
