WC Pro90 fading copies
  • DeNoize
    • Jul 2025
    thank you in advance,
    denoize
  • TzALbg
    • Dec 2007
    • 111
    Clean precharge corotron, Developer HVPS and make adjustment with PWS.
    Donor Voltage should be from 195 to 250, jump voltage should be bellow 2500
    If it doesn't help replace developer material. If voltage is not in range change donor roll again.
    • DeNoize
      Hello,
      cleaned the precharge corotronand the HVPS several times but the problem
      still exists. Next i will change developer and donor roll as you've suggested.
      I will certainly report back.
      Thank you for your helpful tips
