C8130 Pink Lines (Trailing Edge)
  • Gaffers01
    • May 2011
    • 335
    Hi,
    I have an issue on a C8130 where there are pink lines on the trailing edge of prints/copies on A3 only.
    The lines are NOT in the same place and are NOT anywhere else on the page or size of paper only on A3.
    I swapped the drum and the the LPH but still same issue.C8130 Lines.pdf
  • Murv
    Sr. Escalations Analyst
    • Mar 2021
    • 182
    Re: C8130 Pink Lines (Trailing Edge)
    I can't see the lines on your samples, but that said, have you checked the transfer belt and transfer belt cleaner?
    • Gaffers01
      • May 2011
      • 335
      Ok so an update on this one!
      I went back with Magenta developer unit, developer and a drum unit just to see if any of these would sort the issue
      BUT
      the magenta line has disappeared completely The line had been on the prints/copies for 2 weeks and then randomly just gone
      Left the customers happy but confused
      • Gaffers01
        • May 2011
        • 335
        its on the lead edge on the attached PDF as that's the way they got scanned (near the XEROX logo).
        • Murv
          • Mar 2021
          • 182
          Okay, downloaded the PDF and I can see them now. Very weird. Seem too defined for a dev housing, but the L/R shift is too broad to point at a belt. I would have probably gone with a LPH as well. Either way, glad it cleared up. If you ever find out what it was post it here. I'd be interested in knowing.
          Thx
