Xerox Workcentre 7120/7125 Mismatch colors when copying
  • fadsamniote
    • Apr 2016
    • 80
  • Detonation
    • Feb 2010
    • 410
    Re: Xerox Workcentre 7120/7125 Mismatch colors when copying
    You can also calibrate the IIT (scan unit) from diagnostics, but you will need the Xerox test pattern for that. But most likely you will get an error if you do so. If the colors are mixed up soo badly, it usually a bad IIT PWB.
    • vic4we
      • Mar 2023
      • 15
      Did you get through with repairs?
      • fadsamniote
        • Apr 2016
        • 80
        Nope I just ended changing the machine , easier for us...
