any tech facing blur copies after continue 500 print or copy?actually i got 2 cases for imari /arita and copy/print quality is a main issue for this model . print blur or black or yellow toner runs out so fast and within one week waste toner container full only for black or yellow waste toner section. i replaced new developer and developer assy and do max setup ,the problem still remain ?any help
dcc320 color machine imari
any tech facing blur copies after continue 500 print or copy?actually i got 2 cases for imari /arita and copy/print quality is a main issue for this model . print blur or black or yellow toner runs out so fast and within one week waste toner container full only for black or yellow waste toner section. i replaced new developer and developer assy and do max setup ,the problem still remain ?any help -
Actually, you don't need to replace the deves. you just need to use tone judge to get it back to the standard/ desired quality.
The problem lies with the customer. I suspect that the machine printed solid backgrounds that starved the k and y deves. This is a limitation as the machine is classified as an office colour. If the customer wants solid background printing, they need a graphic arts machine/ docucolor seriesComment
my team member tried to tune up until desired black solid but it happens drain up all black developer ..so next visit i need replace black developer .Comment
DCC320 COLOR -
HI,
I had a similar problem & it was caused due to NVM value of ATC sensor setup - corrupted. Pls chk against ur machines's Birth cert. You also have to chk if the ATC sensor / dev tank assy has been replaced before ( if that is the case - chk if the ATC sensor id need to be updated ).Comment
i had updated the current ATC for black developer but problem remains same so i replaced deve harness solve the problem...thanks TECHMATE ..Comment
