System error
+ More Options
Posts
  • Reeves
    • Apr 2012
    • 294
    [Misc] System error
    I have a Xerox wc7855 displaying system error. Power off then On and notify system admin the machine is not running dev motors are not rotating only main motor what could be the cause no error code for the fault i have changed the developer drive assembly and main board still the problem is there
  • xcopytech
    • Aug 2006
    • 1792
    Re: System error
    Can you enter in service mode and check fault history
    • Reeves
      • Apr 2012
      • 294
      Re: System error
      345-354
      • xcopytech
        • Aug 2006
        • 1792
        Re: System error
        Check Fuse 15 on the Motor Driver Main PWB.
