versant 180 colors not aligned
  • lion_heart
    • Jun 2014
    • 174
    good day, been having this issue for a few weeks, have changed all the drums, and it happens with various colors, as you can see in the photo (this time looks like cyan) it is off by a few mm., doesn't happen to all the prints, and only happens at different points, it's very weird any suggestion, versant 180IMG_2344.jpg
  • xcopytech
    • Aug 2006
    • 1794
    Re: versant 180 colors not aligned
    Process direction?
    • lion_heart
      • Jun 2014
      • 174
      Originally posted by xcopytech
      Process direction?
      i print mostly on 12x18 and 13x19
      this happens on 120gsm also on 300 gsm gloss if that's what you are asking
      • xcopytech
        • Aug 2006
        • 1794
        No.
        Is color missergistration in peper feed direction or not.
        • lion_heart
          • Jun 2014
          • 174
          Process direction?
          yes it is in paper feed direction
          • lion_heart
            • Jun 2014
            • 174
            this is a next example
            • Milo Wilson
              • 502
              Check the firmware level. Also check the timing wheel that rides on the fuser belt.
              • lion_heart
                • Jun 2014
                • 174
                Re: versant 180 colors not aligned still same issue but update
                Good day, still have the same issue. but the strangest this is this, it only happens on long sheets, eg. 11x17 or 12x18, if i am printing 8.5x11 or smaller the colors are aligned and print perfectly. My tec says it can't be MOB assembly if it is intermittent (not on all the prints, some big sheets print fine) It's like 7 out of 10 prints bad, and also i change the second btr assembly, still no luck.
                • xcopytech
                  • Aug 2006
                  • 1794
                  Check fuser drive
                  • lion_heart
                    • Jun 2014
                    • 174
                    thanks a mil. can you elaborate just a little more please on what to check thanks.
                    • lion_heart
                      • Jun 2014
                      • 174
                      Check fuser drive
                      • lion_heart
                        • Jun 2014
                        • 174
                        would like to give an update to this. changed the Heat Belt Encoder Assembly and that resolved the issue for whoever runs into this problem
