Xerox Apeosport V C3375 Dead no turn on only main power lamp
  • oscar808080
    • Jan 2023
    • 2
    [Dead] Xerox Apeosport V C3375 Dead no turn on only main power lamp
    2 month ago i bought Fuji Xerox Apeosport V C3375, first time i turn on the machine, 010-375 error happened, then i make it clear by push PowerSave+Stop+4 -power switch on thus there are no problem machine had been ready, they were printing normally after several days i turned off the machine by push the soft button - machine was load to turn off, the progressive bar was almost end, but accidently main switch button hit.
    i turn on main power switch - main power lamp was turn on than i push the soft power switch but no happened anything no lamp accept main power lamp, no light on the disply, no hear any sound of relay. DEAD.
    i check the the circuit breaker there is no problem it works normally
    i check the power supply than track and check wire and connector only 5V turn on on several grey wire
    any helps from the advance please or any experience, what should replace or check
  • Antoni
    • Oct 2023
    • 1
    Re: Xerox Apeosport V C3375 Dead no turn on only main power lamp
    [ATTACH=CONFIG]56270[/ATTACH][ATTACH=CONFIG]56271[/ATTACH]
    Check thermostar??apakah terhubung.jika ia silahkan ganti thermistor
