Xerox J75 White Spots
  • mntech
    • Aug 2010
    • 250
    [CQ] Xerox J75 White Spots
    I have a J75 that has splotchy white areas in all colors, worse in lighter density
    Customer has two of the same machines, so I've already swapped out the primary transfer unit and the 2nd BTR unit with no change.
    The first example picture is printed on a normal weight gloss stock, the second picture is the transfer belt stopped just after the first 4 color bars are transferred to paper(I manually advanced the belt to see both patterns).
    The third picture is non gloss, the spots are harder to see, but the colors look more washed out, almost as if you can see the grain of the paper in the colors.
    The only thing I can think of is voltage board for the 2nd BTR.
    Thanks in advanced for any tips or suggestions.
    -MN TECH
  • xcopytech
    • Aug 2006
    • 1785
    Re: Xerox J75 White Spots
    Yes, 2nd btr hvps
    • mntech
      • Aug 2010
      • 250
      Do you know the part number for the 2nd BTR HVPS? My old arse PWS has the BSOD and needs to be re-imaged
      • xcopytech
        • Aug 2006
        • 1785
        105E20740 2nd BTR HVPS
