Colorqube 9303 Doc Feeder Rollers not lifting
  • tekkie
    • Mar 2011
    • 112
    [Misc] Colorqube 9303 Doc Feeder Rollers not lifting
    Hi Guys help with this old model appreciated
    The Doc Feeder Works fine apart from the fact that the doc feeder rollers dont lift up to allow you to put the originals in to scan
    If you lift the rollers by hand and put your docs in under the rollers and pres copy it ffeds fine and then after the last original has fed the doc feed rollers dont lift up as they should ready for next use.
    Everything is in right the nudger motor and cam assebly doesnt turn to lift them back up
