Help with Xerox 700
  • eng_usama
    • 115
    Help with Xerox 700
    Hello guys issue with Xerox 700 it begin with error code
    042-322 I change drum unit cyan then sweep Motor id drum with magenta then change mcu no difference same error last I change Drum Motor PWB it give error 091-213
    So with machine drum motor pwb error is 042-322 if I change the drum motor pwb it give 091-213 any idea guys ?
  • adriansto
    • 2383
    Re: Help with Xerox 700
    42-322 = Cyan Drum Motor Drive Failure. Someting wrong with that motor. It is blocked or without voltage.
    91-213 not exist in service manual. Probably it is 91-313 = CRUM ASIC communication Failure. You are wrong with of mcu pwb change or other pwb and the machine dont read the drum cip.
    Always is good ideea to have and read service manual before making these moves.
    • eng_usama
      • 115
      Thanks very much brother
