Xerox Versant 80 - Toner readings stay at 100%
  • devonarchibald
    • Feb 2023
    • 3
    Hi all. I'm new here but have owned the Versant 80 for a year. Noticed that the toner reading stays at 100% until it tells me its time to change. Would prefer to see the reading move with use.
    Any input will be appreciated.
    Devon
  • InterfaceP
    • Jun 2013
    • 489
    Re: Xerox Versant 80 - Toner readings stay at 100%
    If I'm not mistaken its the Toner CRUM chips and not the V80 that's causing thius.
    • devonarchibald
      • Feb 2023
      • 3
      Thanks for the response. I was lucky to have the issue resolved. It was CRUM related and was corrected by changing NVM values.
      • mercadoven
        • May 2014
        • 22
        Hi, I'm having that same issue with a Versant 80, Can you share the NVM values that helped to correct the problem?
        • devonarchibald
          • Feb 2023
          • 3
          Steps attached.
