Xerox Large Format Copier 6204 copies come out blank
  • manuelubau
    • Aug 2011
    • 62
    [Dead] Xerox Large Format Copier 6204 copies come out blank
    Hello Everyone!!!
    I've been trying to help rebuild a Xerox Copier 6204. The initial issue was that there were blank lines appearing in the copies and prints. The scanner worked fine and nothing bad would show up on the scanned documents. We replaced the magnetic roller and the cleaning blade. During this process, the user console broke and had to be replaced as well. After this all copies and prints come out blank. We thought that maybe the LPH assembly was bad, but we replaced it with a refurbished one and we are still getting blank copies. anyone has any suggestions we can try? I am thinking that maybe some kind of setting was reset when the User console was replaced?
    Thank you!
  • dtolind@gmail.com
    • Jan 2025
    • 1
    Hello manuelubaum
    maybe you can help me mashine 6204 was dead issue was dell pc power block. Now mashine is alive no error printing and copying only problem what and prints and copyies are blank no prints. Could it be controller isue that was problem in your case?
