Versant 180 inserting tabs using interposer
  • big mike
    • Sep 2012
    • 140
    With the Versant 180, using CWStation 6.8, with printed tabs in the interposer/inserter, won't work. It says it's the wrong size/direction. I told it it's letter size, 9x11, still won't work. I can put them in tray 5, set it as letter size tabs, and it will work. This defeats the purpose of having an inserter on the finisher. The only way it will work so far, is using it as a copier, with letter size paper in the inserter.
    Sending the same file and tabs to a Versant 80 and C75, it will pull tabs into the job like it's supposed to. I select T1 for paper source and leave the others at document settings. I assumed the newer finisher on the V180 should work as well.
    I am using CWS 6.8 (newest), the V180 s/w ver 80.35.41, bustled controller v1.2, interposer is an OAE. Do you think we should try an older level CWS? Like 6.2?
  • xcopytech
    • Aug 2006
    • 1783
    Re: Versant 180 inserting tabs using interposer
    Versant 180 sw should be 80.5x.xx
    Versant 80 sw is 80.3x.xx
    Maybe to reload correct software first
    • big mike
      • Sep 2012
      • 140
      Sorry, it has 80.53 (not 80.35). It was loaded with the newest before installing two weeks ago. I got to use it for 5 days before installing it, added the inserter on site last week.
      • xcopytech
        • Aug 2006
        • 1783
        Bustled or standalone fiery
        • adriansto
          • 2375
          There is bulletin in inserter tech eka number 1449944 from 2020-04. Read it.
          • big mike
            • Sep 2012
            • 140
            It's a bustled fiery.
            • big mike
              • Sep 2012
              • 140
              I will read it, thanks. Next week, I will try the same print job on another V180. Also, there may be a way to print it in one pass (b/w tabs from T6, two sided color from T7). Are there EFI training videos available on YouTube?
              • big mike
                • Sep 2012
                • 140
                My snaps must be an older version, I do not have it. Is there a way to send it?
                • adriansto
                  • 2375
                  Send me email at stoadis@gmail.com
                  • xcopytech
                    • Aug 2006
                    • 1783
                    Check pdf
                    • xcopytech
                      • Aug 2006
                      • 1783
                      What sw version is on fiery?
                      • big mike
                        • Sep 2012
                        • 140
                        Check pdf
                        I will check the nvms this week. It's connected to the interface, makes sense. Thank you!
                        • xcopytech
                          • Aug 2006
                          • 1783
                          Also check fiery software version
