Altalink C8045
  • big mike
    • Sep 2012
    • 155
    Altalink C8045
    I may need to order a system disk from Xerox. My pws shows the part number as 121E28131. When I called to check the price, they said the part number was not valid.
    In past years, they would tell me the new part number and price, so I could keep track. Does anyone know what the new number is? I appreciate your help.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Altalink C8045
    You can use any hdd just altboot machine
    • adriansto
      • 2392
      Re: Altalink C8045
      121E32860 = 500GB
      • big mike
        • Sep 2012
        • 155
        Re: Altalink C8045
        Thanks, I will do that. My error is the same as the other tech's 316-720. I have reloaded software, no issues. Replacing the hdd on the C80xx and the C81xx family, gives me the decrypt error, like his. Can I get a copy of your pdf 'read me procedure'? I can get the other files, just want to read what process is involved in reloading the dlm. That would get me on track for future issues.
        Thanks,
        Mike
        • adriansto
          • 2392
          Re: Altalink C8045
          Thanks,
          Mike
          Nothing special. Put the files on root of the usb stick and perform Altboot like normal.
          After that do machine settings.
          • xcopytech
            • Aug 2006
            • 1794
            Re: Altalink C8045
            As adriansto said, nothing special, you just need special altboot files
            • big mike
              • Sep 2012
              • 155
              Re: Altalink C8045
              Thank you, I'll give it a try
              • big mike
                • Sep 2012
                • 155
                Re: Altalink C8045
                [ATTACH=CONFIG]58160[/ATTACH]
                Thanks, I'll do it!
