C70 machine sanitization HD wipe
  • Tonerkiller
    • Oct 2012
    • 668
    I have a C70 that I have to clear all the data from the machine before I send it back to the leasing company. Is there someone that can give me the steps to do that. I am not trained on Xerox. I have worked on Kyocera for 20 years, so maybe I can help you some day. PM is ok.
    Thank you
  • Dech1
    Senior Engineer
    • Dec 2022
    • 59
    Re: C70 machine sanitization HD wipe
    Thank you
    Switch off
    Hold in the power save- 6 - Stop and switch on while holding in the buttons. you will see a hdd formate appear on the screen.. now let go the buttons and let the machine boot up
    Hold in the power save- 4 - Stop and switch on while holding in the buttons. you will see a hdd formate appear on the screen.. now let go the buttons and let the machine boot up
    Hold in the power save- 1 - Stop and switch on while holding in the buttons. you will see a job log clear appear on the screen.. now let go the buttons and let the machine boot up
    Hold in the power save- 2 - Stop and switch on while holding in the buttons. you will see a factory reset appear on the screen.. now let go the buttons and let the machine boot up
    • xcopytech
      • Aug 2006
      • 1792
      Last option will clear machine serial number from sys pwb.
      If you do not know how to recover machine do not perform last option
