010-398 on DCIV5070
  • Popolopo
    • May 2023
    • 134
    010-398 on DCIV5070
    At first left cover sign on even though it already close, open and close it doesn't help (077-301). Few minutes later, 010-398 appear.
    Already change the interlock switch for left cover, the wiring for that switch, MCU, fusing unit fan, remove duplex unit. But the problem still haven't resolve.
    Any suggestion to fix this?
  • shinchan
    • May 2011
    • 197
    Re: 010-398 on DCIV5070
    I've encountered this. But no solution so far.
    What I've done:
    1. Swap and replace left interlock switch.
    2. Swap left cover
    3. Swap ESS
    4. Swap MCU
    5. Swap Fuser
    6. Replace Exit sensor
    I will try replacing the EXIT PWB. The square PWB on the right to toner hopper
    but your error 010-398
    is fuser exhaust fan failure... try to replace the fuser exhaust fan, its the nidec brand fan located on the rear side of machine
    • Popolopo
      • May 2023
      • 134
      What I've done:
      2. Swap left cover
      3. Swap ESS
      4. Swap MCU
      5. Swap Fuser
      Already tried step 1,3,4. Will try the rest.
      Also already replace the fuser fan, but the error keeps appearing.
      • shinchan
        • May 2011
        • 197
        What I've done:
        2. Swap left cover
        3. Swap ESS
        4. Swap MCU
        5. Swap Fuser
        today's work:
        7. Swap Exit PWB.
        8. I traced the left cover switch cable (orange), everything is intact. Tested both side with multimeter, connectivity is fine.
        9. I traced the exit sensor cable, everything is intact. Tested both side with multimeter, connectivity is fine.
        Error 077-301 / close cover A still happens
        • Dech1
          Senior Engineer
          • Dec 2022
          • 61
          today's work:
          7. Swap Exit PWB.
          010-398
          its your duplex fan
          number 23
          077-301
          PS PWB
          check your 24v at j438/1 ( no 24V - Power save PWB)
          Number: 2
          • Popolopo
            • May 2023
            • 134
            Solved by changing EXIT PWB and Power Save PWB.
            That is after changing fusing fan, MCU PWB and disconnect duplex.
            • shinchan
              • May 2011
              • 197
              thank you very much.
              I can confirm that replacing Power Save PWB is the solution.
