Xerox 700 rip fiery e10-02
  • marcocigna
    • Jan 2022
    • 6
    [Error Code] Xerox 700 rip fiery e10-02
    Hello, I need help, I have a xerox 700 printer with rip fiery integrated e10-02, everything was fine until yesterday now it doesn't want to know more than going to 00 on the service panel, it gives me an F3 code that I can't decipher . if anyone can help me thank you
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox 700 rip fiery e10-02
    There is no F3 code in service manual.
    If you checked hardware (hdd, memory, fans) then try to reload system software
    • marcocigna
      • Jan 2022
      • 6
      I tried, but I can't, because it's really stopped at f3, even when moving the levers on the front panel. I state that by connecting vga to monitor it does not give any signal
      • xcopytech
        • Aug 2006
        • 1794
        Software download from usb
        • marcocigna
          • Jan 2022
          • 6
          Originally posted by xcopytech
          Download del software da usb
          i did put it on usb with fiery usb setup tool, the moment i put the pen drive on the fiery and put it in bootloader mode, it stays stuck at f3, please help me
          • adriansto
            • 2384
            Dimm memory bad. Replace it.
            • marcocigna
              • Jan 2022
              • 6
              ok, thanks, I'll try where I can buy it, the model is this UG64T7200L8DR-4ARF, I found one of these from a seller who is a few km away from me MICRON RAM DDR2 400 MHz MT18HTF12872Y-40EA2 1 GB ECC PC2-3200 CL3
              • marcocigna
                • Jan 2022
                • 6
                Thanks for replying to my post, I fixed it by replacing the ram bank
