065-225 Error Code WORKCENTRE c405
  • tekkie
    • Mar 2011
    • 114
    [Error Code] 065-225 Error Code WORKCENTRE c405
    Hi guys any help or guidance would be appreciated .I have a Workcentre c405 that works fine on copy print and scan on every function until you attempt to do a 2 sided scan on both copy and scan to folder or scan to email but only on the DF.
    You can scan 2 Sided either copy or email on the glass but not from the DF.
    Scan on single sided is fine.
    When you select 2 sided scan through DF and the document is in the feeder as soon as you press start the machine errors straight away without attempting to feed the document and comes up with the error code 065-225 every time.
    The RAP suggests its a CIS issue in the DF
    We had a good working machine in the workshop so we have changed the DF complete still no joy
    We have searched edocs and done everything we can see
    1.Replaced LV Power Supply
    2.Replaced the main board ESS-PWB A that the ribbon cables from the scanner and DF plug into
    3.Reset mc to factory defaults
    4.Reloaded latest firmware via USB altboot ruling out firmware corruption
    Still has same issue
    Would love help or suggestions
    Thanks in advance
  • mojorolla
    The Wolf
    • 2634
    Re: 065-225 Error Code WORKCENTRE c405
    Not sure about a WorkCentre C405 but, the Versalink C405 are known for the CIS units to fail. Have you tried running the shading setup in tech mode after swapping doc feeders?
    Crack open the scanner cavity and swap out the CIS unit works 9 out of 10 times.
    • tekkie
      • Mar 2011
      • 114
      I am just back from holiday
      Saw your advice I am back at work on Monday will let you know what I find
      Thanks for the help
      • Hassann
        • Jul 2023
        • 85
        Hello everyone
        I Have same problem with c405
        Could you please tell what you did to fix it Thanks in advance
