initialised all nvm on xerox 570 now printer is showing 045-315 error
  • Shahn
    • Aug 2017
    • 30
  • adriansto
    • 2392
    Re: initialised all nvm on xerox 570 now printer is showing 045-315 error
    If you worked on machine then:
    • Check that the Flat Cables are seated at the ROS Assembly (Y, M) and at the MCU PWB.
    • If the Flat Cables are seated correctly, replace the Flat Cable.
      If this error appeared without worked on machine probably defective nvms from machine pwbs.
      Try to reset the nvms again.
    • Shahn
      • Aug 2017
      • 30
      i did reset it again , but no use... can anyone tell me nvm codes for that issue please !!
      • WIWA
        • Mar 2009
        • 97
        don,t know the reason for nvm inizialization ,assuming you did not work on laser units , so lets start did you enter manually the nvm factory values (paper located at tray 1or 2 side) if not should be your first step after that enter the newest developer housing adc sensor values ,turn it off/ turn machine on with open door and try to get in diagnostic and try a procon on to push the machine to adjust if everything goes well do adjustments like tray 5 , IBT belt tracking as so on.
        Hope this helps,
        Wiwa 72 Gonzos build v.1.0
