the laser unit seen to fail few m/c laser unit fail c/y anyone face the same problem
dcc6550i laser unit fail
hi,
the laser unit error could be due to the poor contact of the flat cable.
Flat cable contribute to error codes related to ROS. Try replacing the Flat cable - if problem not resolved then try replacing the ROS.
Note: These cables are very tricky to replace ( as it is quite cramped in terms of accessibility ).
Good luck. -
