versant 80 toner compatible with 770
  • croma
    • Oct 2014
    • 87
    Is it possible to insert Versant 80 toner inside the 770? has anyone tried? can it cause problems over time?
  • SeniorTch
    • Jun 2017
    • 116
    Re: versant 80 toner compatible with 770
    Yes, but you must to exchange the 770 plastic key cover and toner chip to the toner V80 cartridge.
    • croma
      • Oct 2014
      • 87
      and there is no problem with the toner fusing or sticking?
      • Detonation
        • Feb 2010
        • 392
        No, it is physically and chemically the same toner.
        • Caffeine
          • 389
          Hi, it isn't the same toner actually, it is one generation newer. The particles are smaller and it is slightly less glossy. It is however completely compatible. Both in terms of development properties and fusing, it will work just fine.
