D125 paper into drum cartridge contniuos jaming
  • SeniorTch
    • Jun 2017
    • 117
    [Jamming] D125 paper into drum cartridge contniuos jaming
    Hello everyone, I have a paper jamed into the drum module, the paper is stuck to the drum even though the separator fingers are fine. The code 77-106 is generated because the paper does not pass to the fuser. Changing the drum cartridge does not solve the problem, there is high adhesion of the paper to the drum or to the transfer belt. ,This happens every 3 to 8 prints, no more than 10 prints.
    Thanks for your Help
  • adriansto
    • 2388
    Re: D125 paper into drum cartridge contniuos jaming
    Probably the transfer belt not lifting all the way up to the drum.
    Check for mechanical / electrical problems to belt contact/ retract solenoid or linkage.
