Xerox 5745 firmware update stuck
  • ondemandprint
    • Sep 2016
    • 87
    Xerox 5745 stucks while firmware update. It's always "Print / Copy Engine" ~25%. Other blocks are successful. As a result printer boots till greenish xerox background (without showing actual 5745 model), then reboots, blinks fullscreen green, blinks fullscreen red and loops.
    I tried ALtBoot Install ESS and AltBoot Forced Install ESS both with laptop and USB-flash. I tried 3 firmwares:
    061.130.000.04205 (which comes with AltBoot files)
    061.132.221.21403
    061.132.229.13700
  • wav
    • Oct 2021
    • 285
    Re: Xerox 5745 firmware update stuck
    061.132.221.21403
    061.132.229.13700
    Could possibly be the sd card if that models has one or the cf card
    • ondemandprint
      • Sep 2016
      • 87
      There is only CF-card in FAX module. I can't see any other type of cards on the board.
      • xcopytech
        • Aug 2006
        • 1794
        Check battery on sbc pwb
        • mkdirs
          • Oct 2014
          • 177
          +1
          and the yellow battery on the NVM
          Xerotk.com
          xerox copier technician
