Xerox 700 Error Code 077-103
  • ewisham
    • Oct 2023
    • 2
    [Error Code] Xerox 700 Error Code 077-103
    Good morning, I have a Xerox 700 that is generating the error code 077-103 with all paper sizes and and weight. It jams in the same location each time. I have attached pictures to illustrate where the jam is occurring.
    Thanks in advance for any advice.
  • xcopytech
    • Aug 2006
    • 1794
    Re: Xerox 700 Error Code 077-103
    Check fuser exit sensor or replace fuser
    • ewisham
      • Oct 2023
      • 2
      Thanks xcopytech for your quick response. Will give an update.
      • Dech1
        Senior Engineer
        • Dec 2022
        • 61
        this is your code meaning:
        Paper to be output face up (straight output), which is being transported through the Fuser, has not turned OFF the Fuser Exit Sensor within a specified time.
        Procedure
        Check the following:
        • Turn OFF then ON the power.
        • Check that no out-of-spec paper is used.
        • Check the Paper Path for foreign objects.
        • Check the Paper Transport Roll for wear and/or deterioration causing transport failure.
        • IOT Exit Motor[077-034] for operation failure. (PL 17.2)
        • Fuser Exit Sensor[010-201] for operation failure. (PL 7.7)
        • marcodm
          • Jul 2023
          • 3
          did you fix the problem??
