Xerox C60 - Can't send anything to print with Tray 6...
  • xXFlipPTXx
    • Mar 2021
    • 26
    i wonder why i can't send anything to print to Tray 6, automatically goes to Bypass 5...
    In the Fiery Workstation says that Tray 6 is "oversized", can't see that problem because i can make copy with Tray 6 paper in it...
    Can't see any tray issue...
    Any solution?
    Forgot to say it's mentioned Tray 6 (AACS)...
    What's AACS?
    Thanks,
    Flip
  • xXFlipPTXx
    • Mar 2021
    • 26
    Re: Xerox C60 - Can't send anything to print with Tray 6...
    Help?
    • xcopytech
      • Aug 2006
      • 1792
      Do you have ohcf or hcf?
      • xXFlipPTXx
        • Mar 2021
        • 26
        Ohcf
        • xXFlipPTXx
          • Mar 2021
          • 26
          Any clue to solve this?
          Thanks,
          Flip
          • adriansto
            • 2383
            Thanks,
            Flip
            If you can copy from tray6 then nothing wrong with it. What machine print driver do you use?
            What is the size and weight of paper you use in this tray? Any type of size, weight, type of paper dont work?
            What Fiery do you have - standalone or integrated?
            Seems print driver problem= settings or Fiery settings.
            • xXFlipPTXx
              • Mar 2021
              • 26
              I use a SRA3 paper, 200grs. I use the same settings that i use in Bypass 5, i only change the tray.
              When i send to print, with Tray 6 on, it goes to Bypass5.
              Nothing related the type of paper.
              Fiery is standalone, a box behind of the printer.
              The fiery is the latest version, all updated.
              • adriansto
                • 2383
                This is integrated Fiery. What serial 5PBxxxxx or R7Bxxxx?
                • JeeDayHS
                  • Jan 2021
                  • 18
                  FIrst try to use copy no print option and select tray 6.
                  If Copy be fine with select tray 6
                  Change print driver on your PC
                  • xXFlipPTXx
                    • Mar 2021
                    • 26
                    still can't send/ print anything from tray6. If i do a copy (scanner) the tray6 works. The workstation have the latest version/driver. Which driver you recommend that works?
                    I send the screenshot image that shows the issue on Workstation.
                    This gallery has 1 photos.
