Xerox c1000 error 10-310
  • MRJESSE
    • Jun 2017
    • 54
    Just picked up a Xerox 1000
    Replaced the fuser belt, belt oil wick and cleaned out the fused assembly.
    Comes up with error 10-310.
    I have attached video of the yucky noise it makes.https://youtube.com/shorts/IS8RJSeG_-Y
  • Guest
    Re: Xerox c1000 error 10-310
    Check the External Roll Motor Assy, and the external roll couplings from it.
    Also check if NVM Value 744-912 is more then 140 or not.
    • MRJESSE
      • Jun 2017
      • 54
      NVM Value is less than 140.
      external roll motor is working.
      • xcopytech
        • Aug 2006
        • 1794
        Fuser belt speed sensor.
        • adriansto
          • 2392
          Be sure the belt rotate and not slipping.
          • Dech1
            Senior Engineer
            • Dec 2022
            • 62
            010-310 Fuser Belt Speed Sensor Fail [IMG]file:///C:/Edoc/common_e2/images/full_a.gif[/IMG]
            Detection Condition
            The Fuser Belt Speed Sensor output is monitored continuously when 1000ms or longer has passed after the Fuser Motor On but the sensor output does not change.
            [IMG]file:///C:/Edoc/common_e2/images/warning.jpg[/IMG]
            Before doing any procedure other than such checks as diagnostic ones that are made with the machine alive, be sure to turn OFF the machine.
            Electrical Parts to Check
            • The table shows the electrical parts related to this Fault Code for display. Utilize information on the table below for making a decision as to whether an electric part is good or not. After making a decision, replace the part as required.
            • When checking electrical parts, check connectors as well.
            • To decide whether individual parts such as sensors and motors are defective, go to 2.2.4 Generic FIPs.
            1 Belt Speed Sensor 7.4.12-27 DC330[010-105] CH10.7 / 7.2.1.16 PL 7.13
            2 Fuser Motor 7.4.5-77 DC330[010-001] CH10.7, CH1.33 / 7.2.1.27, 7.2.1.107 PL 7.12
            3 FSR/INV Core PWB 7.4.2-32 - CH10.7 / - PL 18.7
            4 FSR/INV 1 SNR PWB 7.4.2-21 Refer to 2.2.1 CH10.7, CH1.35 / 7.2.1.16, 7.2.1.10 PL 18.7
            5 FSR/INV 2 SNR PWB 7.4.2-22 Refer to 2.2.1 CH1.35 / 7.2.1.10 PL 18.7
            6 FSR/INV_2 MD PWB 7.4.2-30 Refer to 2.2.1, REP 18.7.2 CH10.7, CH1.35 / 7.2.1.27, 7.2.1.10 PL 18.7
            7 DST 2 (IOT-R) PWB 7.4.2-27 Refer to 2.2.1 CH1.35, CH1.33 / 7.2.1.10, 7.2.1.107 PL 18.7
            Mechanical Parts to Check
            • The table below shows the mechanical parts related to this Fault Code for display. Utilize information on the table below for making a decision as to whether a mechanical part is good or not. After making a decision, replace the part as required.
            1 Check the Encoder Roll and the Belt Encoder for wear and damage. PL 7.13 CH10.7
            2 Check the Fuser Belt for wear and damage. PL 7.4 -
            3 Check the Fuser Motor Drive Gear for wear and damage. PL 7.12 CH10.7
            If though you have made all the above checks and referred to a specific piece of problem information released, you cannot resolve the problem, contact the support division for instructions.
