Need help xerox 700 print quality
  • n893
    • Jul 2020
    • 17
    [Misc] Need help xerox 700 print quality
    Dear all
    I had issue with xerox 700 print using 260gsm paper setting
    The result always have stirpped line on half of the print area.
    We tried to change new drum but no luck...
    If we print using thin paper setting will be ok. But on thick paper the toner not fuse well
    Please help
    Thanks everyone
  • xcopytech
    • Aug 2006
    • 1794
    Re: Need help xerox 700 print quality
    If you have unfused parts on print then you should try with new fuser
    • n893
      • Jul 2020
      • 17
      Unfuse only if i use thin paper setting on 260gsm paper... if i use 260gsm setting on 260gsm paper all fuse well but the line come out
      • xcopytech
        • Aug 2006
        • 1794
        You have to stop paper at 2nd btr transfer.
        Then you will have a part of image on ibt belt so you can see do you have lines on ibt belt
        • n893
          • Jul 2020
          • 17
          Thanks i will try it tomorrow...
